Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Sziasztok! A fent nevezett szárítógép bekapcsolás után pár mp-ig rákapcsolja a fűtést de utána leveszi és nem szárít! Az lenne a kérdésem,hogy- ha van benne nedvesség érzékelő -hol van?Melyik részén? Milyen elven működik?Valaki ismeri ezt a gépet jobban(nálam)?Már több is került ide ebből a fajtából meg a Whirpool-változata is és nem igazán tudtam elmélyedni bennük.
Köszi a választ!
Bauknecht WAT UNIQ632AAA DirectDrive felültöltős mosógép motor nem indul. Nem volt még dolgom felültöltős DirectDrive motoros mosógéppel. Bekapcsolom centrifuga programra, ajtózár lezár, mikor a dobot kellene megpörgetnie, egyet-kettőt "nyekken" majd csend, kb 1 perc múlva ugyan ez és utána kiírja az F07 hibakódot. Ahogy néztem neten ez a motor Triak hibára-ra utal, de mivel ez DD motor nem triak hanem egy külön meghajtó IC vezérli. Azt kellene kiderítenem hogy mi a hibás. A DD motor, a hal szenzor, vagy a meghajtó elektronika.
Amiket vizsgáltam:
- A motornak 3 kivezetése van, mindegyik között 15 Ohm-ot mérek.
- a vezérlő elektronikán van egy 400V-os kondenzátor azon csak akkor van feszültség egy pillanatra mikor a motor próbálna elindulni (nem tudom ez jó-e így).
Képek:
https://drive.google.com/file/d/1XpJaxGIoY55qB9oiEIlXP2kEO8v8TY62/view?usp=sharing
https://drive.google.com/file/d/1ktRIUfqKuMm7vJOaHdDkRlcWbdZGT3MK/view?usp=sharing
https://drive.google.com/file/d/1OQW8dOGbdG3c7y09o86WSKOIBo0cGBe7/view?usp=sharing
https://drive.google.com/file/d/11ltf-IU35Y8OgJOptMAJGIvDApcHvNIQ/view?usp=sharing
https://drive.google.com/file/d/1e-2y3t6-xljFOqsshujZTCG9IQwXUttg/view?usp=sharing
https://drive.google.com/file/d/1vWwWW_RdqvpS1EWrBy6t8gmW2JPYtg83/view?usp=sharing
https://drive.google.com/file/d/1W4Wen1LYorK5ylne37GkLjBBlvPyo50J/view?usp=sharing
https://drive.google.com/file/d/15JRCuBSlNRij5pEbWjWt1N57-mbLB03p/view?usp=sharing
https://drive.google.com/file/d/1aqHbJAki5GYR_iXxl90E110xpE0sm5Zt/view?usp=sharing
https://drive.google.com/file/d/1HrPMNv6uw0iEnJlY5zGJ7ckzyyGuvF3v/view?usp=sharing
https://drive.google.com/file/d/1GY-RIE3WmcbeYW1QTjsUHa1E-UZMa9Db/view?usp=sharing
Videó:
https://www.youtube.com/watch?v=uv0xYFOx2mc
Van ötletetek hogyan tovább?
Köszönöm előre is.
Üdv.: G.
A fent említett mosógéphez keresnék eprom tartalmat, sajnos csak minden második program működik,a többnél még az időt sem jelzi ki.
Sajnos nem találtam itt a tanyán, de ha hasonló whirlpool dumpja lenne valakinek az remek lenne.
Előre is köszi mindenkinek!!
A moderátornak üzenem,hogy ennél érthetőbben nem tudom megfogalmazni...
A hibás topik idítójának üzenem, hogy nem az érthetőséggel, hanem a cím végleges kialakulásànak idejével van a probléma!
