Kérem kockás és CRC ne szóljon a topichoz!
Mi lehet ez a hibakód?
Köszi
Trying to locate a part number: RC2-2879-000 for a Canon office printer, having no luck. Attached photo of it here.
These use to be rebuildable, where you could snap them open and replace the IR diode and receiver, but not sure if thats still possible.
Canon MX 475 nyomtató 5012 hibajel törlése (Megoldva)
A készülék 5012 hibakódot ír ki. Tudom törölni, de kis idő után újra bejön és nem működik a készülék.
Van esetleg javaslata valakinek, hogy mi okozhatja?
A honlapján azt javasolja, hogy vigyem szervizbe.
Minden segítséget köszönök!
Saw lots of videos on these with error code B200. Cleaning the head seems to solve it many times.
So after I put the cleaned out printhead back in, I did the trick again
where u power it off when the carraige is half way to the left, remove power
andapply power.
This time, it said "processing" on the screen, and the carriage did alot of
extra maneuvers, and looked like it was attempting a cleaning cycle.
At the end, the screen said "cover open", and the carriage slid toward the
left,stopped, and (3) cartridge LED's were flashing slowly, which I was told
meansthose cartriges are low ink. If I closed the cover, the B200 error would
eventually come back.
I asked the customer if he had spare cartridges, and he did, so he bought
them over, we put them in , tried again, and same B200 error.
I told him its likely a print head, and he may try ordering one thru ebay or
something to give that a try. Apparently there are microelectronics inside these
heads? Beats me how they control or regulate ink flow. On the back of the head there are about
50 contact pads, which I guess must be sensors of some kind? He did say he took the head out
at one point, and perhaps ESD may have damaged some sensitive circuitry in
there, and now the head is out of spec.
I thought I saw some russian videos jumpering some of the pads on the head to bypass the code....anyone have any success?
