KENWOOD RXD-DV9 SM
5.1 MB
KENWOOD RXD-DV9 SM service manual (1st page)
Preview of KENWOOD RXD-DV9 SM [1st page]
KENWOOD RXD-DV9 SM service manual (2nd page)
Preview of KENWOOD RXD-DV9 SM [2nd page]
    KENWOOD RXDDV-9 RXDDV9 RXDDV RXD DV9 RXD-DV9
Kenwood KDC8070 kikapcsol
Kenwood KDC 8070 cd-s autórádió,bekapcsolástól számítva pontosan 30perc elteltével kikapcsol,és csak áramtalanítás után lehet újra bekapcsolni,a menüben nincs kikapcsolási időzítés,tehát valami más baja lehet.Ha valaki tud segítsen,előre is köszi!FLY001
Kenwood KA-3500 Integrated Amp BIAS Adjust
Hello, Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape. Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors? -- On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me. -- I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were? -- The service manual is on site here. Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read. I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty. -- Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2: Bellarmine
Kenwood kdc-psw9524 probléma
Sziasztok. Adott egy fenti autórádió.(dupla előlapos, jó kis cucc lenne..) A gond: Hozták, hogy nem kapcsol be. Nagy nehezen kideritettük, hogy nem a saját levehetó előlapja van rajta, hanem valószinüleg egy másik készüléké.( teljesen megegyezik, még a leirások szerint is) Ahogy olvastam ez csak a saját előlapjával megy, de hátha van rá megoldás.. ( a régebbi maszkos modellekhez is voltak olyan eprom tartalmak, amiktől nem kérte pl. a maszk kulcsot...) A készülék nem lopott( az ismerösőm akié, nem olyan ), hanem angliából való, így már akitól vette, az sem utolérhető. Esetleg valami ötletet várnék a megoldásra. Köszönöm. Sziasztok.
Kenwood autórádió kiszedő(KLUCZ-65.242)
sziasztok: ha valakinek lenne kéznél ilyen, és megmérné a méreteket, megköszönném. Bálint
