PANASONIC TX-P42VT30B TX-P42VT30Y CHASSIS GPF14D-E
9.2 MB
PANASONIC TX-P42VT30B TX-P42VT30Y CHASSIS GPF14D-E service manual (1st page)
Preview of PANASONIC TX-P42VT30B TX-P42VT30Y CHASSIS GPF14D-E [1st page]
PANASONIC TX-P42VT30B TX-P42VT30Y CHASSIS GPF14D-E service manual (2nd page)
Preview of PANASONIC TX-P42VT30B TX-P42VT30Y CHASSIS GPF14D-E [2nd page]
    PANASONIC CHASSIS GPF-14DE TXP42VT30B TXP42VT30Y GPF14DE TXP 42 VT 30 GPF 14 DE TX P42VT30B P42VT30Y GPF14D GPF14D-E
Panasonic TX-29PS2P villámos.
Sziasztok! Több szem többet lát, ide is beírom :) http://elektronline.hu/wwwboard/thread.php?sorszam=394095&reply=6 Üdv: pityesz
PANASONIC TV TH37PA60E tipusú készülék nem kapcsol be
Adott egy PANASONIC TV TH37PA60E típusú készülék és az a probléma vele ,hogy Standby LED villog ,és bizonytalan a készülék bekapcsolódása.
A P-Boardon cseréltem a puffer kondenzátorokat de semmi javulás.A tápban a relé nem marad "behúzva".
Kérnék szíves segítséget!!! Előre is köszönöm.
RGB Mod in Panasonic CTP-2780SF
Anyone ever do one of these to a CRT?
Seems like the set has this jungle IC which will be where the RGB lines
for the OSD are needed for the mod:
https://pdf1.alldatasheet.com/datasheet-pdf/view/13342/PANASONIC/AN5304NK.html
Am not sure what the line would be that tells the chip to turn the OSD on. Apparently there
is a line if its 1 volt or more, it activates the OSD, if zero its normal video.
Also I think there must be a sync line tapped into which is bought out to the rear of the set,
with the (3) RGB lines / jacks but not sure where that would be tapped into?
I am gonna use BNC jacks, not the scart connector.
There are some youtube videos about RGB modding and lots of topics on the shumps
forums but so far it seems no one has tried this with Panasonic.
Steve Hearns
Technotronic Dimensions, VT [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
LCD Panasonic
Van valakinek elado alaplap (Mainboard) LCD Panasonic TXL26C10E.
